Operation Round/Oval
For the enthusiast who likes to make, break and recreate all things game related! Discuss painting, converting, scenery etc.
Kaseliegth
Flag: Christmas Island
Postby Kaseliegth » Mon Jan 04, 2016 10:46 pm
Ok I've got to get my tomb kings onto round / oval bases by mid Feb for age of Sigmar
I had them on Sqaure resin bases before but there's no one manufacturer which does all the base sizes needed in a style I like so this is a thread on my progress.
I'm going to make my own resin bases from scratch this way I can just recast them as and when I need the sizes.
Never underestimate a cornered night goblin.
Winner of the last ever game of 7th edition Dark Elves vs Dark Elves against New Ross (Rossi)
The Tomb Kings are on the march again !!! Oh.....Wait.....Maybe Not !!!
Kaseliegth
Re: Operation Round/Oval
Postby Kaseliegth » Mon Jan 04, 2016 10:57 pm
This is how my army looks at the moment
This is the resin and mould kit I'm going to use
Kaseliegth
Postby Kaseliegth » Mon Jan 04, 2016 11:01 pm
The plan was to put together 3 chariot size bases in the style I like together and then take copies of them and cut them down to size.
After thinking about it some more. This way was going to be a lot more costly with doing the rubber moulds and resin.
Kaseliegth
Postby Kaseliegth » Mon Jan 04, 2016 11:04 pm
I decided that I would make my own master copies and then take moulds from them.
This was with just slate and sand filled in the gaps
To try and keep the sand in place I sprayed varnished it.
Kaseliegth
Postby Kaseliegth » Wed Jan 06, 2016 9:20 am
Ok so got 5x oval Calvary bases, 10x 25mm round and 3x 50mm round bases ready to take moulds from
Kaseliegth
Postby Kaseliegth » Wed Jan 06, 2016 9:24 am
Ok silicone rubber made and in
Changed the tubs for ease later
Kaseliegth
Postby Kaseliegth » Wed Jan 06, 2016 9:26 am
Ok note to self.
The rubber silicone mould doesn't wash out so don't use your mothers Pyrex measuring jug to mix it up in :roll:
Kaseliegth
Postby Kaseliegth » Fri Jan 08, 2016 7:47 am
Ok so moulds left for 24hrs and they turned out sort of ok
Some sand from the template has come off so maybe not as sealed as I 1st thought
Kaseliegth
Postby Kaseliegth » Fri Jan 08, 2016 7:50 am
Ok going to to need to be quicker at pouring the resin but it's pretty cool
And then the bases. They have pulled out the sand lost from the templates
Kaseliegth
Postby Kaseliegth » Fri Jan 08, 2016 7:54 am
Ok so they have turned out ok but the gaps between the stones are deeper than I wanted.
I want it to look like a stone slab path which has been left in the desert so the gaps would be filled with sand so going to re-mould them.
Thinking about it I should of just done a tester mould and not wasted all that silicone rubber mould.
Badrott
Postby Badrott » Fri Jan 08, 2016 4:35 pm
To be honest mate they look really good - especially considering this was your first time at it.
Itll be harder to notice those deep cracks once a model is on the base and you've done a paint job on it.
Kings of War UK number one ranked Orc general.
2016 Bristol Vanguard Dreadball League Champions - Da Pirates (Orcs+Goblins)
Sceleris
Postby Sceleris » Fri Jan 08, 2016 9:24 pm
You're right about the test run - but hindsight is a wonderful thing.
Agree that look decent to me. In any event, putting a little extra sand on them would hardly be a major task.
How much did the rubber/resin combo set you back?
Kaseliegth
Postby Kaseliegth » Mon Jan 18, 2016 7:19 pm
Sceleris wrote:You're right about the test run - but hindsight is a wonderful thing.
The rubber resin I got from This seller on eBay
http://www.ebay.co.uk/itm/221175561830? ... EBIDX%3AIT
It's really good and well easy to use
Kaseliegth
Postby Kaseliegth » Mon Jan 18, 2016 7:21 pm
Ok so I've now been busy filling in between the slabs with milliput
Kaseliegth
Postby Kaseliegth » Mon Jan 18, 2016 7:22 pm
I've then added the sand
I've sealed the sand a lot better this time with 2 covers of watered down PVA glue
Kaseliegth
Postby Kaseliegth » Mon Jan 18, 2016 7:23 pm
2nd try and taking moulds of them
Kaseliegth
Postby Kaseliegth » Mon Jan 18, 2016 7:25 pm
They turned out a lot better. Was way better with the PVA Glue sealing them in. Had no sand left in the mould at all.
I then mixed up some resin and started casting my bases
Kaseliegth
Postby Kaseliegth » Mon Jan 18, 2016 7:26 pm
Can't believe how quick you can get these bumped out. As the resin only takes 20 mins to set you can get a load done in an evening.
Kaseliegth
Postby Kaseliegth » Mon Jan 18, 2016 7:28 pm
Started painting them as well now
I was trying to make the sand a bit of a different colour so the base stood out a bit. Basically so it didn't look dull and people looked at my bases than my models lol
Kaseliegth
Postby Kaseliegth » Mon Jan 18, 2016 7:31 pm
Sprayed white and a layer of Steel Legion Drab
The a dry brush of Baneblade Brown was added then Bleahched Bone dry brushed
Kaseliegth
Postby Kaseliegth » Mon Jan 18, 2016 7:33 pm
The sand I did an extra dry brush of Bubonic Brown and then Skull White to add some contrast.
Kaseliegth
Postby Kaseliegth » Mon Jan 18, 2016 7:36 pm
Troops then added
I think it's turned out really well I've been really surprised how quick and easy it is to do.
Going to start on my Monster, Monster Calvary and Scorpions bases yet.
Got 4 weeks left to finish it all up
Sceleris
Postby Sceleris » Mon Jan 18, 2016 9:21 pm
They look really good mate - and seem a lot easier than I'd expected to do.
Kaseliegth
Postby Kaseliegth » Mon Jan 18, 2016 11:03 pm
Yeah I'm really surprised how easy they are to do. Really enjoying this as well.
I'm getting my skeleton archers bases painted up tonight
Dave Fraser
Flag: Micronesia
Postby Dave Fraser » Tue Jan 19, 2016 9:26 pm
yeah top work those, might have to give this a go at some point.
Bueno
Postby Bueno » Wed Jan 20, 2016 2:04 pm
looks good mate, how heavy are the bases?
Twitter: @bueno_ben
Plog: viewtopic.php?f=8&t=1401
Kaseliegth
Postby Kaseliegth » Thu Jan 21, 2016 2:59 pm
The bases aren't that heavy but I haven't done any large ones yet.
Kaseliegth
Postby Kaseliegth » Thu Jan 21, 2016 3:23 pm
Start work on the Monster and Monterous Calvary templates.
Kaseliegth
Postby Kaseliegth » Thu Jan 21, 2016 4:16 pm
Getting my Scorpion and Carrion base templates done as well
Kaseliegth
Postby Kaseliegth » Sun Jan 24, 2016 8:58 pm
So Monster and Monster Calvary bases ready to take moulds
Return to “Hobbycraft”
