HELP: Painting on top of chrome
For the enthusiast who likes to make, break and recreate all things game related! Discuss painting, converting, scenery etc.
ObviousPlayer
Postby ObviousPlayer » Mon Aug 08, 2016 11:13 am
Hello all,
I need some advice. I've sprayed a couple of Stormcast Eternals with a chrome effect spray from B&Q. They look lovely. Super shiny. However, I can't then get any other paint to stick to the chrome. Imperial primer and Vallejo grey primer just slides off and pools. It's like trying to paint on glass. Also, washes behave very strangely and don't flow into the recesses properly. My best bet thus far has been to put down two or three coats of a GW base paint which isn't really ideal.
Can anyone recommend a primer or other solution to get paint to stick to parts that I don't want to be chrome?
Many thanks
Chris
Real Name: Chris Gough
Can play: Warhammer AOS, Batman Miniatures Game, AVP, Confrontation AoR
Interested in: Warzone Resurrection, Infinity
Stu's Idle
Re: HELP: Painting on top of chrome
Postby Stu's Idle » Mon Aug 08, 2016 12:03 pm
It's hard to give advise without knowing more about the paint etc but could you 'key' the area? In other words can you sand/rough up the chrome, giving the next layers something to stick to?
Otherwise all I can suggest is to mask areas before spraying, using masking tape or masking fluid.
Sorry I couldn't be more help.
Flames Of War: Soviets
Team Yankee (6mm and 15mm): Soviets
Bolt Action: Soviets
DUST: SSU aka Soviets (anyone spotted the theme yet?)
Star Wars Armada: Imperials (Space Soviets, a long, long time ago)
Epic Armageddon: Imperials (Space Soviets, in the grim, far future)
Frostgrave: Dwarves (Short Soviets)
ObviousPlayer
Postby ObviousPlayer » Mon Aug 08, 2016 1:25 pm
Thanks Stu.
There's no real chance of keying it. I like your other suggestion through. Will order some masking fluid.
Mark_T
Postby Mark_T » Mon Aug 08, 2016 4:59 pm
Some sort of varnish may work - Matt will be the best but will heavily dull the shine, gloss is the opposite; satin may work.
radegast6@gmail.com
Flag: Poland
Postby radegast6@gmail.com » Sat Oct 15, 2016 8:56 pm
As Mark posted varnish should help. also using oil based paints should stick to it but it will take weeks to paint it.
Username: radegast6@gmail.com
Real Name: Adrian Kramarzyk
Games -Warmachine -Khador,dreadballveer-myn,WarzoneRessurection-Mishima,2nd.ed.BauchausMilitia,Deadzone-all Warpath-Verr-myn,Infinity Ariadna, Necromunda Malifaux - GuildBoard Games-Risk,Zombies!!!,SpaceHulk,ProjectPandora,
Games to be Xwing, Wolfsung
My painting blog -http://miniaturesconversion.blogspot.co.uk/
Return to “Hobbycraft”
